I’ve been building up my new bike, an ’07 Spesh Big Hit – and I’ve hit a bit of a problem in that the ISCG chain device mounting bolts foul the granny mounts on the new SLX crankset I’ve bought for it.
Can’t decide between the following options…
1. Grind granny mounts off crankset.
Pros – I don’t plan on riding up on this bike, so will probably never use them.
Cons – If I don’t take to DH, I might want to use the crankset on another bike with a granny ring.
2. Remove chain device and ride without for now.
Pros – Easy.
Cons – Chain will probably fall off a bit.
3. Buy and fit an alternative chain device.
Pros – Chain will stay onm, crank should still go round.
Cons – Might still have same problem, even with lower profile and countersunk ISCG bolts. Expensive to try.
4. Grind granny tabs off another crankset.
Pros – I have a new Evolve XC crank laying round that wouldn’t sell for a great deal.
Cons – Not so stiff, doesn’t have steel pedal threads.
So, which option would you pick? Or are there any other solutions I’m not thinking of. Suppose I could buy a DH crankset with no granny tabs, but cranksets are quite expensive and I don’t think I need a really heavy duty one.
