Just been using a few different posts recently on others bikes and have really settled on the face that hydraulic is just so much superior to cable actuation. The effort required to move my command post is much more than that of a reverb, for example.
After doing it a few times I have come to the conclusion that this has to be due to the cable friction on the cable housing.
Now, I may be getting ahead of myself here, but perhaps someone can link me to an explanation of how cable housing works. Because I can’t see many reasons not to use a PTFE based housing such as supplied for split gear routing, for the exposed cable, all the way along. Likewise, why can’t I run it through maybe some heatshrink?
I just feel there must be better ways of running cables, perhaps we need the protection for the gearing from the weather, but for a seatpost it’s 0 or 1. There’s not 10 positions it will stop in. The lever is either on or off. Thus any cable wear isn’t going to affect it as much.
On a similar point, why are cable housing run so close in diameter to the cables. Why not give it an extra millimeter of movement to reduce the friction? Or is this just not how it works.
