best way to cut 12m...
[Closed] best way to cut 12mm off a steerer ?
[#502401]
I am wanting to cut a steerer by 12mm - changing stem, headset etc and - it won't work out correctly with spacers etc.
What is my best method ? too small an amount for pipecutters to grip, so am thinking very careful hacksaw and file ?
Posted : 26/04/2009 11:57 am
yup. hacksaw and file. easy.
wrap a bit of tape round it if you think you might stray off line. it's easier to follow.
Posted : 26/04/2009 12:01 pm
Yeh, use a hacksaw and then clean it up with a file. If its an ally steerer you'll go through it no problem
Use an old spacer to cut against.
I've found it keeps the cut straighter.
SB
Posted : 26/04/2009 12:11 pm
 GW
is 12mm really too short for pipecutters? 😕
Hacksaw, can't ever be arsed to clean it up though
Posted : 26/04/2009 12:17 pm
For amounts too small for a hacksaw, I found that a belt sander works surprisingly well
Posted : 26/04/2009 12:51 pm
thanks all.....heads off to B&Q for new hacksaw blades -)
Posted : 26/04/2009 2:26 pm
