The PC951 isn’t nickel plated, the 971 has nickel plated outer plates, the 991 inner and outer, basically means you’ll be able to get them shiny again once they’ve been used, as you’re obviously bothered by such things I’d get the 991.
I’d also recommend not getting rid of your old chain – if you put the new one on and it skips (pretty likely if you ride a lot in winter) then you have the option to put your old one back on and run it into the ground.
I’m currently doing just that after I didn’t change a chain in time, it’s eeked another year out of a cassette, although the shifting is getting sloppy now.
