Depends how you wanna do it, really.
I expect it will be 'isotonic' but that requires you mix it at the correct ratio.
If you don't, then it won't be.
If I am just out on a lng ride, then I use a weaker solution of energy powder than recommended as it's easier to stomach & getting the maximum amount of energy in to fuel you is not critical.
If I am doing an event, then I mix it as recommended by the manufacturer. You need to be careful with this that you don't then start mixing in energy gels and stuff.
There's a Torq nutrition guide that they will perhaps e-mail you that explains it far better than I just have.
