Best GPS Phone cycl...
[Closed] Best GPS Phone cycling app
[#2779246]
hi,
just got anew android htc phone. whats the best app out there, for free, that tracks rides etc. also how relaible is gps in the woods.
friend uses a a garmin which is good.
cheers
s
Posted : 23/05/2011 10:12 am
endomondo
Posted : 23/05/2011 10:15 am
I dont know whether its actually the best - but for ease of use and letting mates see your routes or challenging your mates to different things
Endomondo stands head and shoulders above the others.
Posted : 23/05/2011 10:19 am
I have found the best apps (I use an HTC Desire/android) are sportstracklive for tracking a route and lots of other details. Once uploaded you can also play the route back on Google Earth.
Just started using MM Tracker for OS maps/GPS and very impressed, although this does need memory map on your PC
Both have free trial versions I think, and full version are only a fiver
Posted : 23/05/2011 10:20 am
looks good, will give it a go today
Endo comes in 2 levels the standard Free has most things you need.
the pay version is about £2.50 and has a few fancy extras
both on your phone and online.
Posted : 23/05/2011 10:22 am
I like maverick, again free or sub - free is perfectly good.
You upload/download routes to gpsies.com
it has access to OS 1:25,000 maps - perfect which can be downloaded offline for quick access when out & about.
perhaps I should look at endomondo as it appears popular.
What I have not found is an app that allows you to foolw a route like you would with a purpose built GPS like a garmin etrex.
Posted : 23/05/2011 1:59 pm
 mrmo
I have tried Endomondo and My Tracks, what i found odd was the difference in altitude, surely the phone is using the same code to figure it out and passing the info to the application? so how can the heights be 100's of feet different?
Posted : 23/05/2011 2:05 pm
I use MapMyTracks (Outfront) on my iPhone, and it's easily the best app I've used. I realise you're looking for Android, and currently they don't have an app but apparently they're working on one, and in the meantime there's some apps which play nicely with their site (which is possibly the greatest part, the syncing of rides and data into graphs). http://www.mapmytracks.com/blog/entry/android-apps-that-play-nicely-with-map-my-tracks
Posted : 23/05/2011 2:11 pm
That's exactly what MM Tracker does. You need to be using Memory Map, or have the section of map you need emailed to you buy someone who does. Then it's just like a garmin, you load the GPX file and the gunsight like cursor follows the trail - or not if you get lost as I did yesterday, and it was really useful guiding us back on track.
Posted : 23/05/2011 2:25 pm
doesn't trails do this? may be iPhone only though...
Posted : 23/05/2011 2:29 pm
try [url= http://www.mapmyride.com/ ]map my ride[/url], it works for me
Posted : 23/05/2011 3:00 pm
MM tracker is tied to memory Map which I do not have.
I have tracklogs.
Has anyone tried [url= http://www.appbrain.com/app/viewranger-gps-open/com.augmentra.viewranger.android ]ViewRanger[/url] ?
Posted : 24/05/2011 5:23 pm
