Looking on their site re. bedding in and found this:
Bedding in your Disc Pads
Nick Craig of Scott suggests riding downhill and putting your brakes on until you get your rotor very hot. Then stop to spray cold water from your bottle onto the pads (the water should hiss if hot enough). This process should be done 3 to 5 times and particularly for sintered pads. Muddy water can be used to speed up the bedding in process, but just be careful not to drink this! Rotor condition also has a big impact on pad life. Ideally Nick suggests you should use 4 sets of pads at most per rotor.
Bloody hell – that could be 8 hours in teh peak district
