Hi all,
Last night I replaced the bearings in my Reigns rear hub (Giants own performance tracer). Old bearings came out easily and the non drive side bearing went in a treat. I use my own homemade press which is a threaded rod and a bunch of washers, old berarings, and nuts. Anyway, the drive side bearing wouldn’t go in straight with the first attempt and I ended up jamming it at an angel to the point where the inner race wouldn’t move. Managed to tap it out in the end for a second try. The bearing seemed fine, no roughness/notchyness or play. Got it in fine in the end.
However, I’m worried I’ve damaged the bearings inside. Possible? I know the bearing felt like it did before I installed it but that’s not to say I’ve damaged it. Thoughts? Or tips for next time? I’ve used my homemade press successfully quite a few times now. I’m considering buying the RRP press adapters to help with alignment for next time.
Thanks
Colin
