BBs for Truvativ St...
[Closed] BBs for Truvativ Stylo Chainsets
[#1527203]
Ive got a 2006 truvativ stylo chainset and cranks. The BB has had it. Do I have to get a truvativ one or can i buy Shimano, Hope, Chris King etc.
Posted : 20/04/2010 3:49 pm
If its lasted four years, then I'd be inclined to stick with the same anyway. They're only twenty quid on CRC
http://www.chainreactioncycles.com/Models.aspx?ModelID=19366
I wish I'd had a bottom bracket last four years. A few of mine have lasted that many weeks
Posted : 20/04/2010 4:16 pm
You can only use Truvativ GXP or Hope with the adapters, which are easy to fit.
I agree. If you have had that long out of one, I would be happy! But if you fancy a change, I am running a Hope with SRAM XX and so far so good.
Posted : 20/04/2010 5:13 pm
If it is GXP and its just the bearings that have given up then you could just get new bearings.
Posted : 20/04/2010 5:35 pm
Good advice chaps. How can i find out the bearing sizes. I'm thinking i could buy some better quality bearings and fit in the same cups.
Might also look at the hope adapters. Hmmmm
Posted : 21/04/2010 9:54 am
This Enduro guide is fairly good but you do not need the fancy tools
as you can see, just reuse the reducer /adaper.
The HOPE adapter is for anyone that does not already have a BB to reuse the reducer from.
http://www.hopegb.com/page_mep_force_57.html
Any bearings are better than Truvativ bearings.
There are various thoughts on external BBs.
http://www.singletrackworld.com/forum/topic/htii-bearing-help
Posted : 21/04/2010 10:10 am
