Just to add: The tiles are going round the sink and toilet, because I went with laminate panels for the shower area (1400mm x 900mm) – mixed results though. Lovely surface and quick to install without worrying about leaking grout, but you do get paranoid about sealing the edges, and if you have shower plumbing behind it you have to be very confident it’s not leaking, or you have to remove the whole panel or cut through it…
For my next bathroom I’ll probably go with the more expensive acrylic panels around the shower but tiles on the section with the plumbing, or if I get laminate again I’ll get the fancy trim that holds it at the base up away from the shower tray rather than relying on just silicone.
