- This topic has 106 replies, 48 voices, and was last updated 9 years ago by bobgarrod.
Banning high-powered kettles next
molgripsFree Member
lots of people drive huge cars short distances every day without thinking that they could walk that mile to the shops or take their child to nursery on the back of a bike.
Yes, I know, but you’d be surprised at how much other things add up. Look at the whole picture, don’t just focus on the headline stuff.
Incidentally most people I know don’t fly anywhere.
mikewsmithFree Memberpdw – Member
Other considerations aside, a lower power kettle will actually be less efficient than a higher powered one. It’ll take longer to boil the same amount of water, so more energy will be lost to the environment whilst it’s heating the water, and more energy will be consumed overall bringing it to the boil.as pointed out earlier it’s a study not a law which means it’s options being looked at. Perhaps banning kettles completely would be better. It also gives people the opportunity to look at designs.
wreckerFree MemberThe amount of water in the kettle is the important factor.
The amount of energy required to heat water of a certain volume is the same regardless of the the heating element power (energy = power x time).
higher power element = less time. Lower powered element = more time. Specific heat capacity of water = constant.
Pretty brainless policy (suprise surprise).
They’d have been better off making the volumetric capacity of the kettles smaller (say 2 mugs max).IanMunroFree MemberIs it? Why don’t you do some calculations?
Because if I did you’d only take issue with them 🙂
If I need to heat up a litre of water it takes a given number of joules -let’s say 350Kj – that figure is assuming we’ve got a perfect insulator – which we haven’t. The longer it takes to warm up the water the more energy leaks to the surrounds and the less efficient it becomes. For a given volume of fluid more power is more energy efficient (at the point of heating)
Now you could argue that it would encourage people to use less water, but if you’re already a good ecologically minded person you’re already using the minimum quantity, only now you have a less energy efficient kettle to do it with.29erKeithFree MemberMaking a kettle more efficient is certainly an interesting concept. Where is the waste energy going – heat?
Well I’m no expert (stereotypical STW IT bod) but can come up with a few ideas straight off (I’m sure a few others may have suggested some or all of these, I’ve not read every post)
-The casing of my kettle gets hot each time it’s used, and that heat radiates into the room, that’s wasted energy. The water could possibly be insulated somehow maybe, something like a jetboil? maybe
-Kettles are open to atmosphere so heat is wasted their. could that be sealed? Much like a litre of water on the hob boils quicker when it has lid on.
-Far too many people boil way too much water not just what they need (these include my wife despite much nagging, my mum, my grandparents). many people don’t think! so need to be lead\pushed! So those boil water tap kettle things seem like a good idea too.Many manufacturers making money doing what’s cheap and easy often need a push to innovate. Some don’t, Dyson for example. As I understand it not one of their vacuums use more than 1600w anyway….
Some people need pushing, it’s a good thing IMO vacuums, kettles, irons, hair-dryers etc. Yes for most of those the gains might be small but look after the pennies and……..
CougarFull MemberWe all need to be more efficient in our use of energy really so going after all the power hungry appliances that are more powerful than they need to be to mitigate poor design seems a good place as any to start
If we’re going to start anywhere, it should be the modern trend for appliances in “standby” and leaving chargers plugged in 24/7. I wonder how much we’d save if we switched off / unplugged everything we weren’t using?
CougarFull MemberPretty brainless policy (suprise surprise).
It’s not a policy.
How am I going to efficiently boil water for my pasta?
somewhatslightlydazedFree MemberDid you know it takes about 14 litres of water to make one plastic kettle?
Anyway. Here are some tips on how to make a better kettle
The energy consumption of a kettle depends on:
Thermal mass of materials that are heated while the water is heated. New thick film heating elements are available and have a much smaller thermal mass than traditional concealed elements and immersed coil elements. A manufacturer of thick film elements estimates that up to 20% energy saving may be achievable
Heat loss from external surfaces. This is dependent on the wall’s thermal conductivity, so low thermal conductivity plastic is superior to higher thermal conductivity metal.
Ability to heat a small amount of water and no more than is needed. The accuracy of the level indicator is important, but education of the user is most important.
Heat input continues after the water reaches required temperature (boils) until the automatic cut-out actuates. The time this takes depends on the overall kettle design and so can vary considerably. It is important that this time does not increase with use, however, it is one of the more common complaints that automatic switch off times tend to lengthen with use and for some models this will continue until the kettles will not switch off at all
Then make sure the kettle will not fail if its used 8 times a day for 5 years and you’re laughing.
IanMunroFree MemberI wonder how much we’d save if we switched off / unplugged everything we weren’t using?
To quote David Mackay –
“If everyone saves a little – we’ll achieve only a little”.wreckerFree MemberHow am I going to efficiently boil water for my pasta?
How much pasta do you need? 2 mugs of water would do a lot of pasta.
Do you have a gas hob? You do know that gas is far less carbon intensive than electricity don’t you?It’s not a policy.
What is it?
vickypeaFree MemberIt would be useful to know which appliances guzzle the most power when left on standby, and how much that would cost per year. That could motivate people to switch off.
CougarFull MemberWhat is it?
Lazy journalism, mostly.
See for yourself:
http://www.bbc.co.uk/news/business-29004060
It’d do a lot of crap pasta; pasta needs a lot of water to move around properly as it cooks. But, alright then, I’m making a big pan of soup instead.
CougarFull MemberA comment on the story nails it.
Araxmas
7 MINUTES AGO
Another non-story.
The EU commissions these research initiatives all the time, the problem is that the media pick it up and jump to conclusions about things being ‘banned’.
How many times has the Daily Mail or UKIP gone on about toilet flushing, fishermen, compost, olive oil, danish pasteries .etc being banned? It is all bunk that is caused by them rushing to conclusions.vickypeaFree MemberIf you skimp on the water when cooking pasta it doesn’t cook evenly and clumps together!
wreckerFree MemberNo wonder I don’t eat pasta. Mine has always been crappy saucepan cooked.
RustySpannerFull MemberLet’s start by ensuring all offices turn off lights and computers at the end of their working day, wherever practical, obviously.
Free hats, compulsory socks with sandals and small generators implanted into the wrists of teenage boys, thus charging their smartphones with one hand whist watching them with the other.
lerkFree Memberandytherocketeer – Member
I’d aim at things like aircon. By definition inefficient. On for extended durations, and a net heat generator whose job is to make cold.
edit: or at least rule that they must be solar powered or somethingThis ^^^
A device which in most cases is required when it is hot and sunny and already requires pipework and cables running outside…
Also why not include water cooling for preheating Domestic hot water supplies?
To me, these are the sort of ‘low hanging fruits’ (bleurgh bullshit-bingo time!) that should be prioritised rather than short cycle appliances such as vacuum cleaners.
That said however, the kettle and corrie bit is very much an issue for energy generation purposes. With smart TVs and PVR’s, it would be easy to phase homes to distribute the ad-breaks across the 15 minutes between existing peak loads.molgripsFree MemberI wonder how much we’d save if we switched off / unplugged everything we weren’t using?
Not much nowadays. Modern chargers use very little when not being used for instance.
miketuallyFree MemberIf you turn your central heating right up, and run all the burners/rings on your hob too, you’ll increase the air temperature in the kitchen. This will decrease the temperature difference between the external surface of the kettle and the air and so it will lose less energy to its surroundings and be more efficient.
Afterwards, open your fridge and freezer doors to cool the kitchen back down again 😉
mikewsmithFree MemberLet’s start by ensuring all offices turn off lights and computers at the end of their working day, wherever practical, obviously.
Turning your computer off and on each day is not actually that efficient. The big start up buzz of the fans etc. draws a lot of power. Using proper power saving etc. and standby can be better.
Debates like this need facts not opinions.andytherocketeerFull MemberWouldn’t worry too much about stuff on standby. There’s already the 1W initiative, and the total consumption is peanuts. Certainly in terms of cost to you on your leccy bill (how much would 8kWh set you back?).
The answer there is Nintendo Wii (which are really bad in standby iirc), probably Xbox and PS3/4 too, your PC, and Sky box. And most of those (at least Sky/Freeview) really “need” to be kept on, since in Standby they actually do things.
wreckerFree MemberI’d aim at things like aircon. By definition inefficient. On for extended durations, and a net heat generator whose job is to make cold.
edit: or at least rule that they must be solar powered or somethingAircon has been aimed at. Statute dictates that operators of AC must have a TM44 AC efficiency inspection every 5 years, and that systems must be leak tested periodically (they don’t “make cold” though :D)
A 4kW PV panel which *could power a small split system would be 21 off 235w panels.Let’s start by ensuring all offices turn off lights and computers at the end of their working day.
Good luck with that! Automation is the key. People don’t take ownership of light switches in places they don’t pay the bills for.
If the Uk really wants to save energy, retail is the first place I’d start;
Make supermarkets put doors on chilled cabinets. Govt doesn’t have the appitite for this.
Ensure supermarkets maintain their refrigeration to a reasonable standard (they don’t).
Ensure that shops can’t run AC with the ****ing doors wide open.
Zero lights after trading. I don’t need to know that there’s a primark in the area at 2300hrs!
Then onto commercial offices, homes etc. There are loads of things we could do but won’t.RustySpannerFull MemberI used to work in the CIS in Manchester – couple of thousand people, most using PC’s.
Last time the calcs were done when I was there it was decided it was more efficient to power down individual PC’s at the end of the day.
Lights were left burning all night before movement detecting lights were fitted.
The problem was actually getting people to alter their behaviour.
molgripsFree MemberThere are loads of things we could do but won’t.
Yep. This stuff is piss easy to do – a lot easier than forcing people not to fly anywhere.
andytherocketeerFull Memberyebbut everyone’s changing 50W halogens to 5W LEDs so can leave them on longer
and probably need an extra 45Wh per light in additional heating in winter
retro83Free Memberstoffel – Member
I don’t understand the fuss over the recent vacuumcleaner power reduction thing. Our Henry is 1200w max,yet much more efficient thant the 1600w Black and Decker crap it replaced.
Well after 2017 you won’t be able to buy one of those either. 😆 900W limit.
molgripsFree Memberprobably need an extra 45Wh per light in additional heating in winter
Probably not…
andytherocketeerFull Member2 hoovers 1 pipe
or replace all the carpets with wooden / laminate / lino floors (and pretend there was no energy expended in their making)
wreckerFree MemberI recently saw the energy profiles for a supermarket which had been subject to a full LED lighting retrofit.
The results were frankly astounding. The baseline was halved.mikewsmithFree Memberandytherocketeer – Member
2 hoovers 1 pipeor replace all the carpets with wooden / laminate / lino floors (and pretend there was no energy expended in their making)
Why when you can get one that works perfectly well with a smaller motor. Big power numbers are a bit of a con, design something that works well with less power and it’s all good.
roneFull MemberDoesn’t heat that is lost in an appliance – transfer to the surroundings, and add to the room temp, therefore a notch less on the CH?
Then it comes down to insulation.
wreckerFree MemberAgain, electricity is lots more carbon intensive (not to mention expensive) than gas.
mudsharkFree MemberI’m thinking rather than bin my old bulbs I should put them back into use over the winter.
roneFull MemberElectricity is more carbon intensive or electric heating? I.e you can do things with leccy you can’t do with gas.
molgripsFree MemberI’m thinking rather than bin my old bulbs I should put them back into use over the winter.
I wouldn’t – they only heat the ceiling, bit pointless for heating rooms. Unless they are downlighters, but probably not very efficient even so.
andylFree Memberwrecker – Member
The results were frankly astounding. The baseline was halved.did it have any effect on reducing the refrigeration loads due to lower store temperatures as well as just the lighting savings?
wreckerFree MemberElectricity is more carbon intensive or electric heating? I.e you can do things with leccy you can’t do with gas.
Electricity is more carbon intensive than gas, so it’s not as simple as tyring to justify GLS lamps by saying you also get heat from them. Any perceived saving in gas by using heat from lamps is not equal in cost or carbon terms.
wreckerFree Memberdid it have any effect on reducing the refrigeration loads due to lower store temperatures as well as just the lighting savings?
I didn’t dial down (not my project), but I can do. I think I still have the sub meter data saved down.
The topic ‘Banning high-powered kettles next’ is closed to new replies.
