Viewing 40 posts - 1 through 40 (of 107 total)
  • Banning high-powered kettles next
  • vickypea
    I just read on the BBC website that high-powered hair dryers, kettles and toasters are next in line to be banned. Surely physics dictates the amount of power to boil a kettle of water, a low-powered kettle would be working longer to do its job? And wouldn’t a low-powered hair dryer or toaster simply be used for longer to do their jobs?
    Does anyone have a logical explanation?
    mikewsmith
    If you can make something more efficient then you can do the same job with less power. A fairly sensible argument and probably going against the trend of bigger numbers is better.
    the-muffin-man
    Lower powered toasters may lead to less burnt toast – a double whammy saving on carbon emissions!!
    aracer
    Making a kettle more efficient is certainly an interesting concept. Where is the waste energy going – heat?
    mtbfix
    Crucially, you’re not going to inconvenience anyone enormously so it’s easy legislation to pass. Limit air travel, huge tellies and ban cars emitting more than x co2 and you’d suddenly have a fight on your hands.
    brooess
    Has Kelvin MacKenzie taken over the BBC?
    thestabiliser
    It saves energy.
    HTH
    ohnohesback
    Stockpile your high-powered kettles now.
    stoffel
    I don’t understand the fuss over the recent vacuumcleaner power reduction thing. Our Henry is 1200w max,yet much more efficient thant the 1600w Black and Decker crap it replaced.
    molgrips
    My dad used to do the calculations as part of teaching – kettles are about 98% efficient.
    I suspect that hairdryers are toasters aren’t that efficient though so with some design work they could be improved. Don’t know for sure though.
    GrahamS
    Heat that isn’t directed towards the water?
    ohnohesback
    So you can voluntarily choose a Henry in preference rather than having the decision dictated to you.
    therevokid
    ever tried getting a decent cuppa from a 2000w kettle ….
    mikewsmith
    Through the sides, using more energy that is required to heat the water – think about it can you touch the side of the kettle as it boils? If you can it’s probably heating the water very efficently. The tap boilers and small volume kettles are the real solution there as most people boil 4x as much water as they need and then most kettles probably get boiled 2 or 3 times before every use.
    hot_fiat
    Please let them go after irons. A more frivolous waste of energy you couldn’t make up. “These clothes are not quite flat so, for pure vanity’s sake, we’ll continually heat some steel with a 2kw element and make them flat.”
    martinhutch
    I already use low-energy tea bags, so it’s not a big deal for me.
    oldnpastit
    Limiting the power of your kettle encourages you to only put in as much water as you actually need, rather than (as my wife does) putting in a litre or so of water, boiling that, and then letting 3/4 of it cool back down to room temperature.
    andytherocketeer
    About the only thing you could do to a kettle is make it switch off 1 deg cooler or something.
    Toasters, well there’s a big gaping hole at the top. Capture that heat to use for something else, or use some kind of laser device than can spot cook the surface of you toast?
    Hair dryer, just turn down the heat a little bit, and have a more efficient blowy motor.
    Sounds nearly as silly as the day that UK “changed” to 230V AC +/- however many percent, instead of 240V. Remember the papers and BBC news saying how long extra it would take for kettle to boil. the voltage didn’t actually change. As we proved a long time after by sticking a multimeter in the mains socket.
    geoffj
    Exhibit A m’lud
    I give you the low energy version
    As ever, the headlines are mainly bollocks.
    Its a study, not even an imminent or even proposed ban.
    Here is the linked report if you can be bothered to read it.
    http://www.ecodesign-wp3.eu/sites/default/files/Ecodesign%20WP3_Draft_Task_3_report_11072014.pdf
    Kettles start at page 55. I’ve only skimmed it, but they seemed to be more concerned with making them more durable, so saving raw materials and energy in construction.
    olddog
    The biggest saving with kettles would be boiling only the water required. I remember seeing a kettle (?) that did this, heated the water as it was being drawn from the its reservoir.
    edit – as mikewsmith said…
    mudshark
    Kettles with insulation seems a good idea; my wife fills up the kettle before making even one drink as saves her walking over to the sink so often…. It does seem to me that the one who isn’t earning the money is less concerned about efficiency than the one who is – or is it just often a woman thing to leave things on when not needed? This is just going on what my mates moan about obviously!
    footflaps
    In Winter, that’s fine as it just acts as a radiator. In Summer it’s a bit wasteful.
    mikewsmith
    also for those miserable gits who want their 6l V8 Kettles because they sound better and the tea tastes much better from a proper kettle/iron/toaster/hair dryer when you come to buy a new one you will just get a new one that does the same job just as well but costs you less money.
    RustySpanner
    Surely the handmade, artisan, 853, slack handled kettle can be boiled atop the woodburner?
    And they’re bringing a new sized toaster out next year anyway.
    It’s inspirational, aspirational and makes your muffins come alive
    IanMunro
    What olddog says.
    In fact putting a power limit on a kettle could be counter-productive to saving energy.
    Let’s say a kettle’s power is limited to 1KW, if I want it to heat as quickly as a 3kW one I could do this by designing the kettle to have a reservoir of water that is pre-heated at 60C, so that the 1KW of power could bring it up boiling in the same time as 3KW.
    Fantastically wasteful of energy, but uses less power. I can’t imagine people would make such a unit, but it highlights the problem of legislating on power rather than energy. I assume that they hope that by reducing power people will put less water in the thing in the first place.
    My home is heated from electricity anyway, so at least with a kettle I get a cup of tea and an extra radiator.
    nickc
    We all need to be more efficient in our use of energy really so going after all the power hungry appliances that are more powerful than they need to be to mitigate poor design seems a good place as any to start
    fasthaggis
    There are very few high powered Kettles left .
    Northwind
    High powered kettles mean you can boil a larger amount of water in the same time as a low power kettle boils a small amount. Which probably explains why everyone in my office boils a gallon of water in order to make a cup of tea- if it took 5 minutes to boil, they’d put in less water to get it to boil fater, and use less water and less electricity.
    Disposability seems like an issue too though. Are higher powered electrical items likely to have a shorter life? Do they consume more resources to produce?
    molgrips
    It did, but the variation in mains voltage is quite high anyway afaik.
    vickypea
    I don’t use a hair dryer and only one room in our house is carpeted anyway, so they can do what they like with appliances 😛
    Isn’t this all a drop in the ocean compared with air travel and people using great gas-guzzling monster trucks to go to sainsburys or to transpet a tiny child to nursery?
    IanMunro
    I think a kettle or toaster’s duty cycle is so low that it would make chuff all difference.
    Now I’ve thought about it a bit more, it may well be more about reducing peak power usage than energy.
    2 million 1KW kettles going on after Coronation street may mean you can use a different energy supply structure compared to 2 million 3KW kettles being switched on.
    molgrips
    Is it? Why don’t you do some calculations?
    Most people boil kettles 2, 3 or 4x a day, but not everyone flies, and most of those will only go once a year…
    klumpy
    Yes. Some people (including policy makers) don’t understand the difference/relationship between power and energy. And you can enact virtually any legislation that makes things slightly worse if you remember to use the word “sustainable”.
    footflaps
    Even if we all didn’t use anything during the day, we’d only reduce consumption by roughly a third:
    [url=https://flic.kr/p/oJbM7H]Weekly Demand[/url] by brf, on Flickr
    Diurnal variation is quite small, we use 20+ GWatts round the clock (I assume Industrial stuff).
    andytherocketeer
    nothing changed to the actual supply. there is no big knob to turn, merely thousands/millions of substations to replace at midnight on harmonisation night. the variation was chosen to so that all EU existing supplies fall within the harmonised range.
    pdw
    Other considerations aside, a lower power kettle will actually be less efficient than a higher powered one. It’ll take longer to boil the same amount of water, so more energy will be lost to the environment whilst it’s heating the water, and more energy will be consumed overall bringing it to the boil.
    It may discourage people from boiling more water than they need, but we’ve already got decent incentives for people to not do that.
    vickypea
    Molgrips – My maths isn’t up to calculations but lots of people drive huge cars short distances every day without thinking that they could walk that mile to the shops or take their child to nursery on the back of a bike.
    And I think you’re underestimating air travel. I travel abroad maybe 3 times a year for work and that’s pretty infrequently compared with a lot of friends or people I work with.
    andytherocketeer
    I’d aim at things like aircon. By definition inefficient. On for extended durations, and a net heat generator whose job is to make cold.
    edit: or at least rule that they must be solar powered or something
    sharkbait
    How about banning the likes of Coronation Street/Eastenders? – in a single stroke it would reduce the amount of kettles being boiled and crap TV.
The topic ‘Banning high-powered kettles next’ is closed to new replies.
