This is on the back brake of a set of OEM Ultimate 7’s of a spesh bike. So I think it is an ultimate caliper with a 7 lever. Not sure if that makes a difference but it might.
Anyway…. the problem is that the pistons are not retacting very much at all so that even when the brake is “off” the rotor is dragging. There is no visable gap between the pads and the rotor.
There is a pad contact adjustment lever – this is currently wound all the way in (so it might be the problem) but last night tried unwounding it and nothing seemed to happen and I never reached a “stop” on unwinding.
If I push the pads apart the go back into the caliper body easily and I’ve tried to clean both pistons so I don’t think they are corroded. Pull the lever and they both move easily they just don’t go back apart quite enough….
Any suggestions appreciated.
