Hello, Im new to this forum
I have been using some second hand juicy 5 march 07 on my bike for a while and they have seemed good. The second to last ride i did the back brake seemed abit soft. I bought a bleed kit from ebay and bleed both brakes as recomended by Sram on there u tube video. I did not have the red plastic dummy pad/disc so bleed the brakes with the disc and pads left in. They seemed much better and sharp.
During the ride today the front brake seemed to go very soft with alot of lever travel (almost to the bars). After the ride I took the pads out to check the thickness they are only 50% worn. I pushed the pistons back and put the pads back in. I have pumped the lever but the pistons to not seem to take up the gap and stay there. The retract back and give you a very long lever.
Any ideas or help as I cant ride the bike with brakes this bad. Not totally sure if its a pad setup problem or a bleeding problem.
Thank You
