Swapping rear 185mm Avid rotor to 160mm - should I order an Avid adapter as well or will my old Hayes/Shimano (160mm) one do the trick?
Thanks
Bike Forum
[closed]
Avid Elixir rear calliper mount question
Posted 1 year ago #
As long as you use a 160mm IS (on the frame) to Post (the calliper) mount it does matter who made the mount or the calliper.
Posted 1 year ago # -
as above,you beat me to it
Even with the cup and cone washers that Avids use?
Yes, as they space out from a standard mount.
I use Hope or Avid depending on which disc does on, still use cup/cone.
Posted 1 year ago #
Topic Closed
