I’ve got a home cinema setup that I’d like to update a little bit. Current setup is a Sony amp (STR-KSL5) hooked up to a 5.1 setup. It sounds great, but the connectivity is lacking and that’s starting to be a bit painful.
The main problem is no HDMI input and only one optical input, which is tied to a single specific source (TV/Sat). I can switch out the optical source between DVD/PC/PS4 by changing cables, but it’s a bit of a pain. Same thing with an optical switch, it’d be a pain to get up and fiddle with.
I’d like to upgrade to something that fits the following criteria at a minimum:
[list]
[*] HDMI output to TV[/*]
[*] At least 3 HDMI inputs (PS4, DVD player, TV)[/*]
[*] PC input support (either another HDMI (which would require a PC upgrade to a newer video card), or an optical connection tied to a specific separate “PC” source – not overriding the other sources!)[/*]
[*] Remote control support – just source selection and volume would be sufficient[/*]
[/list]
In an ideal world it’d also be:
[list]
[*] Cheap – happy with a second-hand model / ebay special[/*]
[*] Silver (to match the other kit)[/*]
[*] Sony (to match the other kit)[/*]
[/list]
Note that I don’t need speakers bundled in, the ones I’ve got at the moment are fine so could do with not spending any more than needed!
Any recommendations from the audiophiles out there?
