AutoCAD LT11 help
[Closed] AutoCAD LT11 help
 TimP
[#2498957]
AutoCAD just crashed and it doesnt seem to have actually saved when I pressed save all day. It has taken me to drawing recovery manager and given me a file from 9:38 which is a .sv$ file. The auto save says it creates a .ac$ file every 5mins but I cant find and file with a suitable file name
Can anyone help?
Posted : 23/02/2011 3:59 pm
Have you tried turning your machine off and then on again?
Posted : 23/02/2011 4:07 pm
Try manually changing the file extension from .ac$ to .dwg (save a copy first)
Edit: to find the files go to
Tools > Options > Files
“Automatic Save File Location” to see where they are
You might need 'show hidden files' checked, too
Posted : 23/02/2011 4:10 pm
 Haze
Is there a *.bak file available?
Copy and rename it as *.dwg and try opening...
Posted : 23/02/2011 4:11 pm
 TimP
I have had to restart
I can't find any files named .ac$ even though autosave apparently creates them, I can only find .sv$ and .bak both of which are very old (ie this morning or yesterday
Posted : 23/02/2011 4:14 pm
 TimP
Cougar, you are a legend
Posted : 23/02/2011 4:32 pm
 kevj
It's in a hidden folder. You need to go to view, file types and uncheck or check show hidden files and folders.
I'm not on a pc atm, so the instructions will be similar to above.
Posted : 23/02/2011 7:38 pm
