Arthritic shifting
[Closed] Arthritic shifting
[#1850815]
A friend of mine has severe arthritis and has difficulty shifting using conventional or gripshift. She will be buying a hybrid soon due to the ailments and would like to have the easiest shifting system, single speed isn't an option!! Anyone got any alternative ideas/suggestions for shifting?? Cheers.
Posted : 01/08/2010 11:47 am
Dual control brake/gear levers?
Posted : 01/08/2010 11:52 am
if she's a woman, shouldn't the bike know telepathically when she wants the gear shifting and do it unthinkingly and without need for any thanks?
Posted : 01/08/2010 12:23 pm
Matrimonial issues iDave??
Posted : 01/08/2010 12:29 pm
+1
Posted : 01/08/2010 1:16 pm
I hate to say it but two thoughts immediately spring to mind, the first being that if said individual is really THAT arthritic, should they really be riding a bike at all? Secondly, if shifting is such an issue, surely braking is also an issue? Which kinda brings us back to my initial concern...
Just a thought, like.
Posted : 01/08/2010 1:20 pm
I think braking is ok, its more a wrist/thumb thing. And i'd hate to be the one to tell her she was unable to ride, you just cant kill some peoples spirit and determination.
Posted : 01/08/2010 1:25 pm
Is it both hands that are affected? I built a bike once which had all the shifting on the left as the guys right hand was still on a minefield in Mozambique
Posted : 01/08/2010 1:36 pm
grip shift? maybe a 1x9 set-up with the shifter on the preferred side if one hand is less affected.
Posted : 01/08/2010 1:40 pm
Exercise is good for arthritis so yes; she should be riding as much as possible....
As for shifting, shimano do a Di2 version of their nexus gears ( http://cycle.shimano-eu.com/publish/content/global_cycle/en/nl/index/products/city___comfort_bike/cyber_nexus.html) not going to be cheap though...
They also do something called the Nexave t300 'tapfire' shifters of which I can't find a decent picture, but designed to be easier to use....
Posted : 01/08/2010 2:07 pm
These are(were) made for drops but could be put on a flat or wave bar. Sontour Command shifters, only up to seven speed, though for a hybrid that could be a goer.
I have a set at the bottom of a box somewhere.
Posted : 01/08/2010 2:31 pm
I've got a similar problem, (mainly on my left hand) and am now thinking about the DCLs as they can be had fairly cheaply these days. I tried lefthand Sram X0 gripshift which does reduce the issue with thumb shifting but puts more strain on the wrist, which are two of my most affected areas. I had a little play around with having both shifers, (1 grip and one thumb), on the righthand side but couldn't get it to sit in a comfortable/usable position.
I have little problem with braking, although I can't 1 finger brake consistently on the left.
Without meds I couldn't ride at all and have learnt to adapt to my condition - I wouldn't contemplate not riding at all unless I got to the stage where I couldn't ride safely. I imagine your friend is fairly similar situation. Personally I find that I can't ride 2 days in a row without aggravating things further but I can live with this.
Let me know how your friend gets on and if they find any alternative options.
*EDIT - Forget to say that although the DCLs are fairly cheap, you need to switch to a full shimano braking system which obviously bumps up the price and may not be what your friend wants.
Posted : 01/08/2010 10:11 pm
Forgot about it earlier, but mrsmidlife's mum has a hybrid thingy with four speed electronic shimano nexus on it, together with drum brakes. She brought it to me to fix a puncture on the back and it was a complete nightmare to undo all the gubbins to get the wheel out. I put a slime tube in to make sure I didn't have to do it again soon, and took it for a spin around town. Some slightly random shifting in auto mode, but not awful, and push button manual available too. The bike might have been Real Cycles, but I'll give her a ring tomorrow and post up.
Edit: this was the gubbins, but the whole bike was maybe £300? nothing like this price.
[url= http://www.commuterbicycles.com/hub.htm ]Clicky Linky[/url]
Posted : 01/08/2010 10:32 pm
