Fell into the trap that I gather many others have last night.
Stripped down a HTII ‘Deore’ BB (new last year) last night and replaced the bearings with std sized 6805’s and found that they are 7mm thick as opposed to the 6mm thick Shimano 6805-RD bearings.
So, first question – is it right that some Shimano HTII BB’s come with 7mm thick bearings? If so, anyone know which ones? If they are out there then I will buy some of these so in future I can replace with same thickness bearings without issue.
Secondly, for anyone that has replaced 6mm thick bearings with 7mm thick ones, what have you done to make up for the extra 2mm width? I have considered turning up a pair of 1.5mm spacers to replace to the 2.5mm spacers to account for the extra width, but then the top hat still sticks out a bit proud, which is annoying. I’ve also heard that the Shimano bearings have a relief on the inside edge which allows the top hat to snap into, so without that the axle might be a bit of a tight fit through the top hat? I’m going to have a look at that this morning.
I don’t really follow how Enduro sell one type of bearing if there are two types of cups out there (unless it’s a myth). I don’t fancy Enduro’s design though, as without the top hat, if the bearings sieze then the axle will be wearing against the steel inner race, rather than a piece of plastic.
Funny how I ran a used Saint BB for a couple of years without problem, and my other bike runs a Hone BB that is still running fine, yet this brand new last year Deore BB has lasted two wet rides! The sealing is pretty crap though, which Shimano chose to use the proper shield on the inside face of the bearing, and then a loose fitting seal the other side, trapped by the top hat. Should have just used a 2RS bearing in the first place.
