• This topic has 8 replies, 5 voices, and was last updated 13 years ago by br.
Viewing 9 posts - 1 through 9 (of 9 total)
  • Are Nevegals better/worse than other tyres for tubeless?
  • poppa
    Just wondering as I have had a couple of instances where the tyre has been a little slow to seal after a puncture. Are Maxxis more robust in general?
    ollie
    I’ve never had a problem with them not sealing when I get a puncture, But they are a pain in the ass to get a new tyre to seal for the first time as the sidewalls leak like hell, Plenty of fluid and a long ride usually does it.
    What sealant are you using, Could It be that?
    poppa
    Stans – had a puncture yesterday at about 35psi and couldn’t reinflate to anywhere near the same pressure.
    foxyrider
    Worse – side walls thin – in contrast never had the same with my maxxis tyres !!
    ollie
    Shouldn’t be a problem with Stans I’ve been using It for a couple of years(and Joe’s) now and It’s been faultless, the only other thing I can think Is that there’s not enough sealant in there or you haven’t replaced It In a long while and It’s lost It’s sealing properties somehow.
    I can’t see It being the tyre as Nevegals are all I’ve used for the past two years and other than paper thin sidewalls I love them.
    buzz-lightyear
    Sidewalls were quite porous and took some effort to seal initially. Note that cold weather affects some sealants quite badly.
    poppa
    Ok. I will check the sealant levels… does the sealant go ‘off’ quicker in some tyres?
    foxyrider
    Side walls failed with me twice now and sealing has been difficult at the bead – v porous – not a fan of the nevgal tubeless 🙂
    br
    I took the last one back I bought as the sidewalls came ready holed – looked like some kind of twin staple hole, and in all in the shop.
The topic ‘Are Nevegals better/worse than other tyres for tubeless?’ is closed to new replies.
