I’ve had a set for 4 years and they’re really pissing me off.
The font is weak, like, I can barely endo with a 200mm rotor.
I have changed the pads, I have changed the rotor.
I’ve even bled it.
It still sucks, and the lever is a little closer to the bars than the rear, especially when squeezed.
Also, the free stroke is huge, on both to be honest, the levers sit waaay out, at the limit of where I can reach, and yet they only hit the rotor at parallel to the bars, and then compress in from there 🙁 [yes I have adjusted the adjustments as far as possible to counteract it, but if I bring the set-point in the levers will hit the bars!]
Is this normal or should I just admit defeat and take it to a shop to get it bled be a better bleeder than me?
The front rotor I have fitted is an Avid, and I think it’s a slightly slimmer braking surface than the original, which probably doesn’t help.
Anyone fancy selling me a genuine 200mm Magura Rotor cheap?
I don’t know about you, but dodgy brakes are a real killjoy, you don’t feel like you can rely on them, and I often overshoot somewhat because of the inconsistency.
I’m just a bit fed up really, and I don’t fancy sending more money after the bad investment thus far [brakes, bleed kit, pads, rotor]….unless there’s real consensus that there’s just something wrong with the front one. I find it hard to compare the front to the rear as the suspension and weight distribution differences mean the rear might be no more powerful, just doesn’t get the same loads. I can lock the rear wheel easily.
According to the old Bikeradar test of this model it should be one of the more powerful brakes, not far behind Saint, yet my friends Saint Mk1’s have always felt like night and day, solid lever feel, utterly progressive and consistent, three times the power.
Help!
