As above really, anyone tried it? Im tempted to try them on my DHX3 on my Alpine 160
Bike Forum
Anyone tried the BETD needle roller bearings instead of a DU bush on a fox dhx?
Posted 1 year ago #
I tried one a while back, the pivot shaft that was supplied was a slack fit in the roller so it knocked, sent it back in the end. Maybe I was unlucky with a undersized shaft.
Posted 1 year ago # -
I've got them on my DHX4 air, very impresses although I'm tempted by the ones you can get from the Enduro seals website from the states when I need to replace them. They have outlasted the DU bush by a long way. BETD is £5 postage which if your just buying one item is steep!
my Betd bushings knocked too, made .1 mm oversized internally and the knocking was cr*p fro something that pricey, contacted BETD by email, no response and couldn't get through on the several times on the phone. Should've just sent back immedietly via signed post.
the enduro ones are apparently much better sealed than the betd ones.
I have some and they are certainly much freer moving than normal bushings.
Also Chris is a real gentleman to deal with, shame UK companies can't match his kind of service. I.e. actually answering emails, replacing failed parts on the strength of an emailed photo without requiring the old bits to be sent back, that sort of thing.
the betd roller bearing is a enduro needle bearing.betd is a enduro dealer
Posted 1 year ago #
Topic Closed
