Viewing 6 posts - 1 through 6 (of 6 total)
  • Anyone run an 03 Spesh Enduro with a 200mm shock?
  • clubber
    I’ve got an 03 spesh enduro which is brilliant (mbr best bike ever 😉 ) except that the bb is too low. I’ve heard of people fitting a 200mm shock to raise the bb up a bit – the std shock is 195mm – but it’ll also steepen the head angle.
    So, anyone tried it?,
    emac65
    BETD do a linkage upgrade for £100 that raises the bb to 13.1″ & gives you an extra 3/4 of a inch in travel
    http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=48&Name=Specialized+Linkages+and+Upgrades
    clubber
    thing is that really i’m happy with 5 inch travel…
    bigyinn
    Cant you turn the flipflop link over to give you a higher BB?
    IIRC you can change the BB height from 13.12 to 13.8″ or thereabout. Does channge the head angle though
    clubber
    clubber
    already using the steeper head tube and higher bb option.
The topic ‘Anyone run an 03 Spesh Enduro with a 200mm shock?’ is closed to new replies.
