I have two pairs of 70's Mordaunt Shorts- MS400 and MS700 72/74
MS700 went through several eras – I suspect these are the latest version
with Peerless 12", Kef mid and Decca tweeter. Power handling was given as
30 watts (speech and music, whatever that means) and a frequency range (not bandwidth specific) of 25-25k Hz. MS400 used a Goodman 12" , with Kef and STC upper units. The spec is much the same as MS700 except the lower end is given as 35 Hz. Both have nominallly 8 ohm impedance. MS700 crossover points are 500 and 3.5k Hz. MS400 points are 2k and 10k Hz. Sensitivity is circa 90dB.
I know people will weep when i say im using these in tandem however after having them tested separately and combined by a sound engineer the conclusion was the whole is much greater than the sum of its parts. Quite considerably.
Currently using a NAD C350 which is ok. Was considering just adding a power amp, and spending the rest on a new CD player.
Alternatives to building amps are a couple of ebay specials –
AMC CVT3030
Or these intriguing units – although obviously a pre amp is required.
Home built amps?
P.S. I dont have 20k a pop for Krells 😉
