I’ve got a bandit 27.5 – great bike. I’ve read that getting the shock push tuned really improves the bike over the stock shock tune.
It’s got a sector fork set at 150 so that’s slackened the head angle to 67.5
I’m a weedy 10.5 stone on a heavy day and I seem to need to run a pretty low pressure (like 110psi) to get full travel out of the shock. That gives me about 25-30% sag as far as I can eyeball. More than that and the o ring doesn’t ever reach the end of the shaft even on a rocky peaks descent. I’m not a total mincer downhill either.
Lots of owners agree that the stock bandit shock blew through its travel easily and although I’ve never felt it bottom out, it does seem eager to use plenty of travel especially when I’m seated and pedalling uphill, it sits a long way into the travel (over 30%) even with the ctd lever in climb. It makes the front end really light.
Descending it’s fast and feels very planted but it’s easy to clip a pedal if the trail “g’s out” presumably because it rushes through the travel easily?
I just checked and turns out I’ve been running the rebound damping really fast – pretty much full speed.
What is a push tune going to do?
