Looking for a trashed clutch mech where the clutch still worked ok? Need the small metal thing that is known for failing, the bit that adjusts the clutch tension, so if you’ve trashed your mech on some rocks or a stick has ended up wrecking it while you’ve been getting all sick and rad, I’d like the internal bits please. Tried to find it online and only found one place that sells it but no stock, contacted Madison and they’ve not replied, posted in the wanted sections but no joy yet so thought I’d try here 🙂
Thanks
