Viewing 23 posts - 1 through 23 (of 23 total)
  • Any welders / Fabricators around?
  • singletrackmind
    I need a guide price for a job I had done .
    It basically involved a butt weld of a 350mm length of 1 3/4″ adapter to a 500mm length . All straight forward clean new stainless 304.
    Weld needed a purge and passivating.
    Part 2 was to literally tack 30mm of 4mm rod to the top of the 1 3/4″ tube
    Parts supplied by the fabricator were 3mtr 4mm rod ( £6 – £9 online ) and 500mm of 1 3/4″ x 2mm wall tube ( £8 – £11 online ), this needed cutting to length from a 2mtr offcut he had in stock.
    I know aalco and Richard Austin metals would have been cheaper.
    In my mind it was a 10 – 15 minute job with zero design work or hassle.
    Quote me (un)happy. nearest £ wins a pint prize
    trail_rat
    10-15minutes ……
    Your not a welder or a fabricator are you ?
    Im going to start at 240 quid.*
    *disclaimer , neither am i a welder fabricator…..but i dabble and i know thats more than 10-15minutes work to do propper.
    mickmcd
    170 quid
    singletrackmind
    He has a machine that does the welding and spins the metal.
    All the user does is align the work, set the amps and press go
    trail_rat
    SO more expensive equipment than just your regular pipe welder.
    mt
    At our place you’d be paying minimum £300 just for the faffage required on the job not the materials or the weld time. You a Yorkshire man.
    mickmcd
    you wont get any change out of 10 k for an orbital welder
    And the guys that used to do pharmaceutical pipework onsite were on two grand a day to turn up and do the business
    revs1972
    £195 + VAT
    It’s magic metal that stainless
    revs1972
    £110 + VAT would be a betterer price though
    kenneththecurtain
    All I do is sit at a desk and click a mouse…
    You’re paying for the kit and the skills required to use it. I’ll go with £300.
    thomthumb
    No such thing as a 15 minute welding job. You have to pay for setup too.
    mt
    Faffage, setup, the skill is in there. You’ll not get em to understand skilled setup, “its just a bit of welding thats all”.
    revs1972
    Hour minimum labour charge
    dropoff
    £762
    breadcrumb
    304 stainless has dropped in price since I last bought some.
    I was paying about £20 for 1m of 2½” 16g 304 ten years ago.
    As above its not 15 minutes work.
    Any lathe work to square and prep the tube?
    jim25
    £240
    trail_rat
    how much was it then ?
    federalski
    £250 all in.
    The anticipation is killing me 😯
    trail_rat
    one suspects it was anticipated to be a bit like any of the bike shops mechanic threads on here – “that shouldnt have been more than a pack of hobnobs and a donation to the guide dogs for the complete rebuild of your bike”
    russ295
    I worked in a fab shob years ago and done lots of stainless work, they used to charge £11 per inch of standard single pass tig welding, that was in the early 90’s tho.
    singletrackmind
    £85 plus VAT
    It took the guy less than 30 mins to make one . I know because I gave him a week to make one. He hadnt made one when I rang up on deadline day and said I’m coming round to collect, and can I have 2 please. He said OK , give me an hour.
    I turned up in 55 mins and they were both finished . Hot to the touch, but finished.
    So the price seems OK . I asked because I can get a coded welder to do a day on site for £300. I was expecting around £120 for the pair give or take abit.
    Revs1972 wins a prize. Some Shimano spd’s ? Got some flats kicking around too, or a nice pair of 26″ tyres ? Will have a search in the spares box and make a list , juicy brake pads new?
    stevied
    £100?
    revs1972
    Yay, nice to know there are fabricators out there who charge a reasonable price .
    No need for a prize ? It’s the taking part that matters 😆
The topic ‘Any welders / Fabricators around?’ is closed to new replies.
