I’ve tried this on a VW forum but no response yet.
B5 tdi sport AJM engine.
I’m trying to replace the sump after it was whacked and leaked after striking a sleeping policeman.
There are two allen headed bolts at the rear, which are located inside the clutch bellhousing behind the flywheel. It’s impossible even with a ball ended key to reach them.
Is there a cut out on the flywheel to allow key access? I’ve already drained the oil, so can’t really use the starter to turn the engine over to find the cut out. What is the easiest way to turn the crankshaft around slowly . I cannot get a socket or spanner on the crankshaft pulley.
