Any recomendations ...
[Closed] Any recomendations for replacement X9 Jockey Wheels!!
[#1309583]
As it says really!!
Any good ones other than buying Sram ones?
Posted : 09/02/2010 9:25 pm
Kcnc make some nice ones.
Posted : 09/02/2010 9:51 pm
And whilst we're on the subject, I can't find any on CRC or Wiggle that are under £30 for an XT rear mech'.
Any thoughts?
Posted : 09/02/2010 9:57 pm
if they are the same as x7, Ive got some you can have for a fiver. Nearly new off a wrecked mech (f***ing useless sram gash)
Posted : 09/02/2010 9:59 pm
Hey kid, if bigman dont take the jockey wheels, i will. cheers
Posted : 09/02/2010 10:08 pm
If yours have seized and they are sealed bearing jobbies, then i believe that replacements are brass bush jobbies, which are much more suited to mud.
Posted : 09/02/2010 10:12 pm
Ok Lee my emal is in profile
Posted : 09/02/2010 10:14 pm
clee cycles do kcnc but they are noisy although the wear is exellent compared with stock ones.
Posted : 09/02/2010 10:17 pm
hint [b]BBB[/b] as good as me old Tacx ones.
Posted : 09/02/2010 10:37 pm
if its just the bearing that has seized just replace it with an £8 SKF bearing (size is 6801-2RS)
Posted : 09/02/2010 10:47 pm
KCNC. Work well and I have no idea if they were noisier than the originals or not.
Posted : 10/02/2010 12:07 am
BBB are very good. They can clog a little, mud gets into the shells and drags eventually but it's the work of 2 minutes to clean them out and it doesn't happen often. The bearings are well sealed so they're rock solid reliable apart from that.
Posted : 10/02/2010 12:47 am
