got a problem with our shower pump (salamander RSP 50)
there is clearly air getting in causing excess noise, reduced power and problems with the auto switch (also may be suffering with negative head)
In the top of the hot water tank is what i think is an 'S' flange supposedly to vent air upwards and encourage a reduced airflow to the shower. As far as i can see the top outlet is linked to the shower and the side outlet of the valve is linked to the general hot water/vent.
We also suffer from very low hot water flow in all the taps and i'm wondering if this is part of the problem
Are the connections on the S flange the wrong way round?
Thought I'd ask on here before calling someone out to fix it
