According to an mot manual i happen to have lying around :
Suitable materials of appropriate gauge and thickness should be used for repairs so that
– Any plating or welding extends to a sound part of a load bearing component, and
– The repair must be virtually as strong as the original structure
So only a continuous seam weld is acceptable for patch repairs, although spot welded joints are acceptable where they originally existed.
Welded repairs to highly stressed components such as steering/suspension arms, rods, levers etc are not normally acceptable.
If it is within 30 cm of a suspension/brake/seatbelt/steering etc mount then for mot standards it does need to be seam welded 100%, even if the original panel was spot welded. basically some mot testers are ****, some are decent are realise that the rules are open to personal interpretation (go-on….. flame me for that statement you armchair car restorers).
