OK, here’s what I would do…
Transform your variables so that z = x/(tho – tci) and y = (thi – tco)/(tho – tci)
Then your equation is z = (y-1)/ln(y)
which requires you to find the root of y – z ln(y) – 1 = 0
Mathematica has an approximate solution for this root, which is
y = -z W(-exp(-1/z)/z)
where W is the Lambert W function. You could use the series expansion of W for this as follows;
Let a = -exp(-1/z)/z
then y = -z W(a)
W(a) = a – a^2 + 3 (a^3)/2 – 8 (a^4)/3 + 125 (a^5)/24 +…
you will then back transform y to get tco. Define a new column in XL for each transformed variable.
Or use Goal seek
😯 Holy batshit 😯 . Goal Seek it is then.
Cheers for the help chaps.
First two drams will be yours. Should be ready in 2027.
