Just trying to keep this civil with the builders doing the extension, so I’ll stick to the facts ma’am.
– Door frame and firedoor fitted. Has a mortice lock which locks fine into the door keep/frame.
– But they’ve ordered the wrong door so it has been replaced.
– When the new door has been fitted the lock no longer works as it’s about 3mm lower than the door keep from the original fitment.
The builder is stating this is what can normally happen and it’s not unusal to have to adjust the door keep.
I’m thinking why to I have to have the nice new door frame hacked albeit by a few mm’s.
Am I being picky? (or to use the builders terms ‘taking the p**s’).
Interested in comments from joiners if this is what you’d expect. I know the door has been done the wrong way as I’d expect you’d fit the door lock first and put the keep on afterwards but as mentioned above that wasn’t an option.
