I replaced all the bearings on my rear pro II hub a few weeks back. Then went for a somewhat biblically wet ride around Brechfa. Cleaned the bike afterward with water, a bucket and a sponge and then left it. A few weeks later and on checking, the rear wheel was noticeably stiff to turn. It has loosened of a bit with some vigorous spinning, but I suspect that the bearings are not all that happy (again!).
The bearings I’ve used are eBay ‘boxed and branded’ jobbies – about £3 each. Not sure if they’re stainless or not, (or even if that would make much difference?). But they seemed decent enough. Surely even half-decent bearings should last more than one (wet) ride?
Is it a chance that the problem lies with the hub, somehow?
Could it be some o-ring or seal somewhere that is to fault?
Ideas please! 🙂
