Hope the hive can help with this one
Loft
I am about to re-insulate the loft, part of it is boarded with 100mm rock wool underneath it. I will lift the boards and put Kingspan on the joists, what is the optimum thickness for this?
Floor
I have a suspended floor with a very spacious crawl space underneath, however the hatch is smaller than the width between the joists, so cutting kingspan to pass down the hole with be laborious and difficult to piece together. Anyone insulated a floor in similar circumstances? What is the best material, amounts and application method. Was thinking I would just shove some cheap rockwool in-between as it would be better than nothing.
Ta
