There are loads of options for aluminium framed glazing, if you’re ok with a 50mm sightline curtain wall system, you could look at the toggle glaze type systems which have the appearance of structural glazing from the outside but a traditional curtain wall box on the inside? The key with these kinds of projects is getting the right installer, some of the products are quite specialist. Have a look at Reynaers, SAPA, Schuco or maybe Smarts but they’d probably be bottom of the pile and try and find a local fabricator/installer as they ‘should’ have the knowedge and experience to do the project justice. Good luck, email in profile if you want any more info, I’ve worked in this industry for a few years…
Oh, and Doc L was mentioned up there, I doubt that would be a problem, u values on sealed units are pretty good with the right spec glass and curtain walling actually performs pretty well thermally.
