StuF – Member
Any experience of this cheap dropper post
Redneck Dropper?
Or any other suggestions, I need a 27.2mm dropper to fit my old Cove HJ. Probably needs to be externally routed as the frame isn’t drilled for an internal one, and there is such limited choice unless I fork out for a thompson one that would probably be worth more than the bike.
Had a Red Neck dropper. The bottom of the seat clamp assembly snapped. It functioned ok and for the record I weigh 100kg.
Was using a KS cruxi 27.2 internally routed post with the cable running through a bottle boss (no drilling) but the cartridge has failed and I need to sort it out.
Also have a Ks Vario with the lever on the post, works well with a little tiny amount of sag. Again the cartridge needs replacement. All the low end KS posts use a sealed cartridge which is annoying also the minimum insertion can be a bit stingy.
