I’ve got a basement with a solid concrete floor – it’s dry and in fairly good condition. At the moment it’s got a nasty carpet laid over some sort of high density foam underlay pads, probably around 8-10mm thick.
I’ve got to take the lot up for the ongoing renovations, but I had planned to lay carpet tiles (mainly for ease) when the work has been done.
Is there some sort of underlay/insulation that I can put down under carpet tiles? I’m concerned that the current foam stuff is probably offering quite a bit of insulation and would like to maintain that if possible…
Thanks!
