Just replaced the stereo in our 07 VW Passat with a JVC head unit so I can get DAB, Bluetooth, USB connection etc, got an iso adaptor for the wiring, aerial adaptor, single din fascia adaptor. All went in well and great sound, much better than the original unit. One issue though, the unit only turns on and off by itself, it’s not linked to the ignition, which I’d prefer particularly so it goes off when you take the key out or on when you get in and put the key in. I put exactly the same unit in our other car (Honda)for the same reason and it’s fine, turns on and off via the key. What’s different about the VW? Presuming I now need to find a live feed on ignition circuit somewhere to connect to the units red power in wire? What’s weird is the original unit did turn off and on via the ignition so I would have thought it would be the same. Confused, any advice appreciated. Cheers
