Would some copper grease do the same job
to be fair that’s what I use in similar applications (like my Alpine 160, or the BB30 bottom bracket I’ve just fitted into my SuperX). Or use a bearing retainer compound to stick them in – you’re trying to stop the bearing from moving in the frame and causing damage so you either need a lube with a solid component (the copper in copper grease, which shears easily) or a compound that stops the bearing moving. Different bike manufacturers have different solutions to the same issue – my Nomad bearing kit came with Loctite bearing retainer, and a quick google shows you can buy a tube of “641” for £6 or £7.
If you are that worried about using the “right” stuff I’d be looking at Square Dog’s recommendation as £10 is not much for peace of mind?
