For sure it won’t go past the maestro mounts, nothing you can do about that. How much seat post is left when pushed fully down? And how much seat post do you run when climbing? When in normal climbing mode, how much post is in the frame?
It’ll also depend on the frame size. My L has about 30cm from top of clamp to the maestro mounts, so with a std seat post I could drop to about 6cm of post showing. Add the top clamp and saddle, that’ll be maybe another 7cm, so you’d have 13cm from top of seat clamp to saddle.
I actually have a dropper on there, which at full drop gives me a saddle height 45cm above the maestro mounts, ie 15cm of seat post and saddle above the seatclamp, so very ballpark the same as with a manual dropped post. I’ve never had a problem at that height, and for most stuff I only tap it down a few cm, I only drop it fully for silly steep stuff.
So in the end – is it a problem it doesn’t drop fully?
