likwid does work on Haswell, I run it every day.
Did you:
1) remember to modprobe msr
2) Try the with/without daemon options
3) if you tried the daemon, is it setuid
One of the above will sort it.
It will tell you CPU power usage so rule out that (or tell you it’s the governor).
I can tell you exactly what the idle on a 4810MQ is this afternoon, as I’ll be sat beside one, but for now I can only tell you I’d expect it to be between 4 and 5 watts. Which TBH is good enough for you to debug.
Both cards are back on again this morning
Sounds more like optimus issues then, maybe some sort of version mismatch. And this sort of nonsense is I why I don’t go near optimus with someone else’s bargepole.
