Bike has on last 2 rides started making a sort of cracking noise when pressure is applied to the pedals – totally silent when pedals turning with no pressure on them, but put some pressure (power!) in them and there is a cracking noise from the rear end. Nothing feels loose or wobbly, what should be tight appears to be – I’ve still to do a proper check on rear Maxle (although that isn’t moving without proper attempts at turning it) and the frame bolts – everything else has been poked and prodded unscientifically. Mate confirmed tonight it is coming from the rear wheel.
Will clean bike tomorrow and have a look but what should I be extra checking? Bike is 15 months old running full SRAM X1 and Guide RS brakes. Thought it could be a cable pinging off a spoke but only happens when power is applied to pedals.
I’m aware this is a proverbial needle in haystack question but what would you be checking and how?
