Another Soul Questi...
[Closed] Another Soul Question
[#3628526]
Considering a Cotic Soul, what size frame are 5ft 8 riders using? 31 inch leg and like shortish stem 70mm ish.
Posted : 31/01/2012 3:26 pm
I'm 5ft 8 and recently settled for a Small frame and 75mm stem, after riding Medium frames. Saddle feels slightly high compared to the rest of the bike to get ideal leg position for xc and a 410 post is a must. Can always drop it for techy stuff if its a problem. Its all good though.
Posted : 31/01/2012 3:38 pm
Same height, same size...^
Posted : 31/01/2012 3:39 pm
thanks chaps! are you both running inline seatpost? or with setback?
Posted : 31/01/2012 3:52 pm
Inline thomson.
Posted : 31/01/2012 3:57 pm
5'8", 32" leg, small Soul with a 90mm stem, I reckon I couldn't get away with a smaller stem tho I'll try it one day if I can blag one
it's very agile. I reckon I could ride a medium too but I'd sooner be at the top of the size range for the frame than at the bottom, and anyway it's for twisty ST
if you're near Surrey, come and try it, email in profile
lots of seatpost showing, right to the limit - a USE Sumo Ti, 10mm offset
ps for people at our height consider getting shorter cranks than the default 175mm, I run 170 and I defo spin up quicker
Posted : 31/01/2012 4:02 pm
ps re the stem I run 660mm bars which the trendies would currently consider 'narrow'. If you're a wide bar fan, you'd probably be able to run a shorter stem too.
Posted : 31/01/2012 4:04 pm
thanks for the advise lads! i'm over in the emerald isle so will try and get a test closer to home!
Posted : 31/01/2012 4:08 pm
I'd suggest dropping Cotic a line, I delt with Paul and he was a massive help in suggesting size, stem, layback etc. and got everything spot on.
Posted : 31/01/2012 4:12 pm
Yep, Paul is the same size as us, and rides a small with a layback, if I recall.
Posted : 31/01/2012 4:18 pm
5' 8" here. I run a medium frame and 90mm stem. Spoke to Cotic and they said I was between frame sizes - I could go small for agility or medium for XC. I'm more of an XC'r and went for medium. Works a treat.
Dan
Posted : 31/01/2012 4:24 pm
711mm bars and inline post too.
medium with 90mm stem 5ft 8? you must have very narrow bars?
@Daniel, you got a pic you could post of your setup?
Posted : 31/01/2012 4:26 pm
711mm wide Easton Haven bars
Posted : 31/01/2012 4:49 pm
I did ask Paul @ Cotic on sizing, he said he's the same size as me and can fit a medium but a small is more fun. esp for twisty singletrack. I never rode a medium but the small defo is fun. I have a medium SC Blur Classic too and it's a tractor in comparison.
@drapper well we're pretty close to Gatwick too, should you be passing thru this way any time
Posted : 31/01/2012 4:54 pm
Cotic must get asked this a lot, maybe then need to do a 'Schmedium' frame size. Until recently (when [s]gets[/s] kids got taller and messed up the figures) we were average height for a male.
Posted : 31/01/2012 4:59 pm
the joys of being on the cresp of two sizes! anyway all advise really appreciated lads
@daniel lovely snap! curious how a 90mm and 711 bar work together.... thought the theory of a wide bar was to be complimented with a shorter stem (sow steering etc).
Posted : 31/01/2012 5:04 pm
 jruk
I'm about to order a large Soul (I'm 6'1") and will be going for a 90mm stem with ~690 bars as I don't like feeling squished. Hope it's about right.
Posted : 31/01/2012 5:07 pm
drapper - Member
OC Tuning have BFes coming out their ears at the moment, get a sit on one of those. They're the same geometry as the Soul.
@jruk - I'm 6'1" on a large Soul, 711 bars, 70 stem, perfect.
Posted : 31/01/2012 5:17 pm
Paul is indeed about 5'8" and rides a small Soul with a 65mm stem, and a slight layback post. From memory he's relatively long leg/short body though.
I'm 5'10" and ride a medium and it's a spot on all day fit (70mm stem, slight layback post), although my small BFe is not too much too small - compact rather than cramped if that makes sense.
Posted : 31/01/2012 5:22 pm
I'm 5'8 (30" inside leg) and ride a small Soul (16" from memory) with a 75mm stem. This feels like a perfect fit.
Posted : 31/01/2012 8:36 pm
5'9" with a 31" inside leg, broad shoulders and longish arms 😉
I ride a medium Soul with a 70mm stem, inline seatpost, 685mm bars, and forks running 140mm travel with 1/3 sag.
It's perfect for me - the small would be too short - my forks are probably a bit too long for what the bike is designed for (120mm?) which would mean I would be over the back on climbs.
IMO if you want a small, get a BFe.
Posted : 31/01/2012 9:21 pm
5'9", 90mm stem but was way too small. Had to get planning permission for the seat post.
Posted : 31/01/2012 10:03 pm
5'8" with a 31 inside leg I ride a medium Soul amd simple with a 70mm stem and a lay back post
Fits me a beaut the small would of felt too cramped for me
Posted : 31/01/2012 11:48 pm
On the small you have a decent stack under the stem to compensate the high Seatpost? 20mm spacers? Keep the for stirrer long is what I'm trying to say
Posted : 01/02/2012 10:01 am
My steerer is presently 200mm, and i believe the Small headtube is 100mm instead of 120mm for the M or L. This has resulted in me initially experimenting lowering the stem height a tad compared to my previous frame, and having a few more spacers above. The saddle height is above bar height but not excessive by any means. I can take some measurements later is you need.
Posted : 01/02/2012 10:57 am
hey scamper you might post a pic of your bike here?
Posted : 01/02/2012 11:21 am
