rab- mine has started doing this (bought 2nd hand and worked perfectly for about a year ago). You need to send yours back as obviously defective.
I’ve added more air regularily and oil (up to the point where it wouldnt go down at all).
I suspect that an air seal has failed / worn and that 2pure are the ultimate answer – or selling it on pinbike 😉
The “pump up to 75psi” bit keeps mine going for about 2 weeks atm and I carry a cable cutter (for the remote cable ties), a 10mm socket and shock pump now in case it goes mid ride and I feel like “fixing” it.
The real mid ride interim bodge is to use the seat clamp to get over the 1 inch floppy bit and drag it up by hand. Not exactly what it says on the tin and all that ;(
Yours doesnt even last that long – let us know how you get on.
