Another cheap XML t...
[Closed] Another cheap XML torch option
[#3380675]
So, I've been doing some research on cheap, bright, 185650-powered torches.
I know we've done one of the Deal Extreme options, but I thought I'd go a different route - mainly because I've had lots of stuff from DX in the past. The quality has been variable and the delivery has been slow.
I did a some research over on Candlepowerforums and decided that I'd try a P60 host with an XM-L T6 drop in module.
As I understand it, it's a bit like lego - you can drop (more or less) any p60 module into a p60 host and it should work. So when a new, brighter LED comes out next year I'll only need to buy a new module rather than the whole torch.
Can't seem to link to larger pics on their website, so you'll have to make do with these tiny ones for now - I might be able to add some of my own tomorrow.
The best value host I could find was the [url= http://www.solarforce-sales.com/product.php?sname=&s=7&t=FB ]Solarforce L2P[/url], which has HAIII anodising and comes in a range of colours. I went for the grey option at $19.99.
I decided I didn't need flashing modes so I went for the 3 mode XM-L T6 drop-in at $17.50.
I also ordered a smooth stainless bezel because I'm fed up of the pointy ones destroying my pocket/bag, and a couple of their protected 18650 cells as they seem to be reasonably well reviewed on CPF.
So it came to ~$56/~£37 all in.
Ordered on the 18th, arrived this morning.
The host/body is lovely - nice colour anodising, smooth threads (they don't appear to be lubed though) and feels nice in the hand.
Changing the bezel and installing the drop-in is easy.
The drop in rattled around a bit, so I wrapped some aluminium foil around it - this should also help conduct heat away from the drop-in and into the body.
Inside it's loads brighter than anything else I've got, though as others have said, the XM-L seems to produce tighter beam than a P7.
Seems a little more purple than the P7's against a white ceiling too, but only barely.
Took the dog for a walk and it's brilliant - the beam is a perfect balance between flood and depth. Can't vouch for what it's like as a bike light yet though, nor for waterproofness.
Niggles/observations:
It's a forward clicky switch, which is taking a bit of getting used to.
All in all I'm properly chuffed - lots of light, (seemingly) good quality, not many pennies, and can be upgraded as and when necessary.
Any questions?
Hope this helps someone!
Posted : 22/11/2011 11:11 pm
 P20
I've seen one of these in the metal they are quite impressive. I've just ordered one for work
Posted : 25/11/2011 7:51 pm
