Hi there!
I know the collective pool of knowledge on the singletrack forum knows no limits, so I thought I’d try my luck at getting a solution to a problem that has been annoying me for a while.
I have a Cannondale Trail2 hardtail. Recently it was converted to a 1×11 setup, using XT single ring cranks, XT 11-42 cassette, XT shifter, and an XTR trigger. I am running a KMC x93 chain. Overall, I have been very happy with the setup, but there is one thing that really toads my sprocket. When I am on the second largest cog (37 teeth), I get a lot of noise from the chain, especially when under a lot of power. It is a sort of rumbling noise, and there is no skipping or jumping gears. No noise at all on all the other cogs.
I have tried adjusting the barrel adjuster. I have measured hanger alignment. I have visually inspected all parts, nothing seems to be bent or warped.
I have only done about 250 kilometers on the setup so far, so I am not inclined to toss the cassette and try another one, even though I suspect that it could be the culprit.
Any ideas to where I should look for a solution?
