thanks papamountain, I think I’ve seen what I need for HDMI switched inputs.
Now I need a 5+ channel Ethernet router. House is Cat5 cabled for three computers – all filled – plus the BluRay player.
Next dumbass IT question (dumbass because I’m a programmer for a living but I know jack-sh** about the hardware side of IT)…
I have a 4 channel ethernet/wireless router plugged into my Cable modem… can I plug another hub into one of the inputs to effectively split it? same way as you’re not supposed to plug a four-gang mains extension into a four-gang mains extension to create 7 mains sockets…
Example: ethernet sockets 1-3 are permanently wired via Cat5 cables to other parts of the house; socket 4 is is connected to the bluray player.
Could I connect another 4 way hub into socket 4 to give me, effectively, 7 sockets? Granted that when one of the sockets on the “new” hub is in use, the others would not be in use?
Dez you’re a star but not necessary, thanks anyways 🙂 they’re not expensive
