Anything sub-eight kilos will feel light. That is still only 17.6 lbs remember.
Just having a play with CyclingPowerLab.
An extra kilo on the flat at 300 watts will take you from 38.315 kph to 38.295 kph (assuming 85kg baseline and CdA of .350 – typical hoods, default environmental values.) Basically costs you about 0.5 of a watt.
On a 10% grade, the extra kilo will take you from 11.814 kph to 11.687 kph. Or about 3.5 watts.
However if that extra kilo makes you a little bit more aero (e.g. deeper section wheels, frame) and takes your CdA down by 0.01 then on the flat you’ll go from 38.315 kph to 38.649 kph. Still be a tiny bit slower on a 10% grade though. Tipping point with those values seems to be about a 3% grade.
But then there is something about a light bike with light wheels that is nice to ride, especially in the hills when speeds are lower and the bike more responsive. But then a heavier bike with deep aero wheels feels great when ridden at speed 🙂
Oh and don’t forget to have a poo before you ride 🙂
