Alternatives to XTR...
[Closed] Alternatives to XTR chainrings
[#1799626]
Am I right in thinking the 970 chainrings are a different diameter to XT?
Do any other firms make half decent rings?
Regards Steve.
Posted : 14/07/2010 7:48 pm
 gee
Hi
TA do some nice ones - Sismic. Alternatively look at Middleburn.
GB
Posted : 14/07/2010 8:16 pm
XTR 970 are the same as XT 770.
I've replaced my inner with an XT and works like the one it replaced.
Posted : 14/07/2010 8:36 pm
Just googled TA and it came up with an old post on from 5 months back. Some good advice on there.
They're a standard BCD, so you can use anything, sort of... The inner ring is 2mm thinner, so you need some 2mm spacers if you want to use a different inner ring.
As Gee said, the TA Sismic are a direct replacement, the outer ring matches the 'profile' of the XTR arms, although there's nothing else particularly special about the M970 ones.
Posted : 14/07/2010 9:07 pm
Cheers guys. Thanks for the info, will sort something out a lot cheaper than XTR.
Posted : 14/07/2010 9:11 pm
Mine have an SLX inner ring and deore middle. And a skinny pointless bashring for a big 😉
Posted : 14/07/2010 10:38 pm
I tried middleburn on M970 & the shifting was never the same. tried lots of different spacers etc. I was lucky to find a full set of M970 rings cheap on ebay.
Posted : 15/07/2010 10:13 am
XTR chainrings last really well for the money. I have had 2 1/2 years out of the same outter and middle chainring on my XTR M970 chainset. I used to go through a set of Middleburn rings every 9 months-1 year. I wear through the inner chainring, at the rate of about 1 a year, and am on my 2nd replacement. Worth considering when you think about the price of XTR. of course they also shift beautifully.
Posted : 15/07/2010 10:31 am
I use deore inner and lx middle I think on my XTR with an E13. It works with the spacers. I took some pics when I last changed them: [url= http://www.basquemtb.com/putting-cheaper-chainrings-on-xtr-cranks/ ]Deore on XTR Cranks[/url]
Posted : 15/07/2010 10:38 am
Sorry for the hijack but it's related.
I have an XT M770 chainset, does this take standard rings or do I have to do the same as the above post link to get deore rings to fit?
Posted : 15/07/2010 11:42 am
XT is standard I think. I think if you get deore though there are a couple of small tabs you have to file off to get the middle to fit. I might be wrong...
Posted : 15/07/2010 3:38 pm
Ta for that doug_, got a few deore rings lying around and didn't like to waste them.
Posted : 15/07/2010 7:03 pm
It's the inner that you need to file the bits off. I've just done it on my XTR!
Posted : 15/07/2010 10:44 pm
